One-man door removal/replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2005, 10:25 AM
How do you remove/replace doors if you want to do it alone?
Martin
Old 02-27-2005, 10:37 AM
BarryK's Avatar
I use a 5gal pail of thinner with the right amount of wood to level the door.
Or I use my little roll around stool with blocks on it.
Have used a jack in past but like the wood wrapped in a blanket for reinstalling as not to scratch or damage.
They sell a door handler but just don't need another piece of crap in garage or basement.
Old 02-27-2005, 03:23 PM
i have also done the jack with wood routine . if the fender is already off , then i like to lift the door into place and latch it onto the striker. then you're only wrestling with the front of the door.
Old 02-27-2005, 03:57 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I've even use my pnumatic roll around shop stool.
Old 02-27-2005, 08:36 PM
What kind of car? If the fender is off (very easy on some cars) the easiest way is to simply put the door in place and latch it. The door will stay up there by it's self. You then insert the bolts and tighten.
Old 02-28-2005, 01:30 AM
Ok guys, I see that it's not really necessary to have one of those door installers even though they're nice. At the moment, I happily don't need to remove my Monte's doors, these would be really heavy I think. But I have a VW Transporter I'll fix up sooner or later and that one has something broken around the upper hinge so that the door hangs. And there's a Mercury Monarch in the garage with all doors removed, these will need replacing sooner or later also.
Regards
Martin
Muscle Cars madhat Hotrodders' Lounge 140 03-08-2007 11:08 AM
TCP Vs. Fat Man IFS 1965-Mustang Suspension - Brakes - Steering 9 11-25-2003 05:01 PM
man o' man.......... crazy larry Hotrodders' Lounge 2 06-11-2003 09:19 AM
Man oh Man!!!!!! slider in wa Hotrodders' Lounge 6 03-16-2003 11:32 AM
