One more 79' firebird question?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2007, 09:59 AM
Tyler
Hey guys, I have to say, this site has helped me so much in my build up..so thanks to everybody that has helped.. i have another question though...my 79 firebird has a 403 with air-conditioning.. i do not want to hook my air conditioner back up..but if i dont, will i still have heat?? will everything still work properly??
thanks alot
Old 02-12-2007, 10:11 AM
There's no reason the heat shouldn't work without the A/C. The defrost might not be as efficient, since it runs the compressor to remove moisture from the defroster air, but that's not a big deal. BTW, I have a '79 T/A with a 403 and A/C, too.
Old 02-12-2007, 10:45 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Agreed. The A/C system's job is to make a little radiator inside the blower box cold. If you don't hook it up, that little radiator doesn't get cold and you don't have cold/dry air. The heat will still work fine.
Old 02-12-2007, 01:07 PM
Just to clarify, the posts above are correct in that simply not hooking up the A/C compressor will not effect the heat. If you start ripping out all the vacuum lines, however, you may remove one that's needed to move the doors in the heater box from hot to cold or from heat to defrost. Get a factory service manual to figure out what stays and what goes.
68 Firebird AC Question SouthernRodder General Rodding Tech 3 05-31-2006 10:51 PM
OHC 6 pontiac into 1979 firebird? Larry Hagman's Liver Engine 4 03-14-2006 10:34 PM
69 Pontiac Firebird HEI Distributor Question pontiac69 Engine 13 12-01-2003 08:35 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Water Pump Question Kaylah Engine 11 08-22-2003 09:35 PM
