one more cam ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2003, 10:12 AM
Post one more cam ?
when setting the lash on my cam it says .022 intake .024 ex HOT whats the lash if cold befor i start it for the first time should i set it at those specs break in cam then reset after break in or is that the wrong way
Old 01-26-2003, 11:09 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
You can set at their recommended settings for hot then start the motor for the first time. Just make sure you readjust when the motor is warm and beware there might be some noise coming from the loose settings untill you readjust.
