One peice 32 hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2013, 11:05 AM
One peice 32 hood
I purchased a haggan 32 ford one piece hood for my 30 model a. of coarse I had to add about three inches length to it to match up with my radiator shell. Now what is the cleanest and best way to mount this thing. I tried running a couple lengths of 1" angle from the shell to the fire wall. Lost my mind. any ideas or pics?
Old 01-06-2013, 04:06 PM
sedanbob's Avatar
The Carolina Customs people make hinge sets for one piece hoods, with or without sides. Looking at their website should give you some ideas if you wan to build your own, or buy one of theirs. I used their hinges for my '33 Ford sedan. I was a universal kit - I had to cut it to length and modify the ends at both the cowl and radiator shell, but they have instructions on how to measue and cut. I run sides on mine, and the hinge rails show if I leave the sides off - there is another design if you don't intend to run sides, where the rail sits up under the hood.
Old 01-07-2013, 05:42 AM
Thanks I will check it out
32 ford, hoo, model a, mount, one piece hood
formula nose peice? 77formulabandit Body - Exterior 4 08-24-2008 09:16 PM
preditor carb peice of *@#~! nitro_baller4692 Engine 7 11-18-2006 05:01 PM
x frame to a one peice driveshaft BRES Transmission - Rearend 0 09-29-2006 07:16 PM
one peice door glass 59 Chev P/U Nowthen50 Body - Exterior 2 07-26-2005 09:30 PM
two peice driveshaft rules KLRS10 Transmission - Rearend 4 03-14-2004 02:02 PM
