My 66 F250 with a 4 speed presently has a two piece driveshaft,I am planning on installing a 460/C-6 that has a much longer tail shaft then the 4 speed and I am considering going to a one piece shaft. I am planning on towing with this truck and I am wondering if a two piece would be better for hauling and towing then a one piece but I had plenty of half tons with one piece shafts and had no problems. Jeff
It probably has a two piece drive shaft to achieve the proper pinyon angle. I dont know that for sure but if that is the case switching to a one piece might drastically reduce the life of your U joints or cause vibration.
I did a quick googly search and found THIS spiffy rod and custom article about driveshaft length.
That article says 51" seems to be some kind of magic number. I know that the driveshaft guy in town won't make them over 72" at all.
As the length goes up, so does the required diameter.
Later, mikey
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
