I currently have a stock 302 2bbl, C-4, with an
open(?) rearend. Could I get some info on what is the difference between limited slip, positraction, traclock, spool etc. And some recommendation on a good gear ratio and the right route to go for power to both wheels. I plan on rebuilding my suspension first. Rebuild and shift kit on the C-4. and getting the 302 to 350-400 horses. Car will be a weekend driver, no track action cept maybe just to see what it will do when completed. thanks.. |
IF your car came with a 302 in a 67 Mustang.......chances are very good that you have a 8 inch series rear end. Anthing other than 1 leggers are fairly rare. You will most likely be forced to go to the aftermarket to get a both rear wheel pull center section/and or performance gear ratios.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Thanks for the explanation on the rearends..
The car originally had a 289 and was changed to a 302 in 74-75. Yes it is an 8". Can I change it over to a track lock? does that just involve changes in the diff. or it the complete rearend? [ February 01, 2003: Message edited by: 67stang ]</p> |
I know Kultulz has info on upgrades for 8-inch rears. If you PM him he will help. I opted to go with a 9-inch, instead of building my stock 8-inch. I found a 9-inch donor at the bone yard from an old MachI for $80.00. Bought a set of 3.70 Precision gears for $179.95 and a Traction Lok dif. for $369.95. Through in some bearings, seals, etc. and I had a fresh 9-inch for about $800.00 complete. I also had to have a driveshaft made. Not exactly pocket change but I don't think I'll ever have to worry about my rear again. I got my parts from <a href="http://www.ReiderRacing.com" target="_blank">www.ReiderRacing.com</a> . I don't know if they have much for 8-inch rears but they have an 800 number that you could call.
Ford did make some 8 inch locker rearends, try looking for them in 1975-78 Mustang 2's with the 302 V8's. The 8 inch rearend is pretty tough but not as tough as a 9 so unless you have over 300 rear wheel HP I wouldn't go through the hassle of changing to a 9. BTW the 70's carriers are stronger than any of the 60's 8 inch carriers. If you cannot find a Ford Locker, there is alway Auburn, Power Trax and Currie that makes lockers for the 8 inch rearend.
