One wire alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2008, 09:43 AM
Irelands child's Avatar
One wire alternator
Currently, I'm stuck with a one wire alternator (Powermaster 100 amp and too many $$$$$ to change), but may change in the future if unhappy.
The wire, a 7ga was in my hand and about to be installed when I had a brainstorm (or possibly something else). With my battery about as far away from the alternator as possible and still inside of the car, I would most likely need a heavier wire. Instead of going clear back to the battery, or in this case, why not use the connection to my Ford SVT mini starter. These new Ford starters have full power at all times. It uses the starter mounted solenoid to activate it. There is another Ford style solenoid at the battery, but it is used solely as a terminal post and a relay for the starter mounted solenoid. Connections from the starter to the battery are 1ga.
I know, confusing, but I can't think of any reason that this wouldn't work.
Dave W
Irelands child
Old 07-08-2008, 05:00 PM
Frisco's Avatar
Glad To Be Here
Dave W
You are correct in your assumption. The HOT wire from the alternator can be connected directly to the battery cable that is connected to the starter solenoid coming from the battery. This will keep the connection fairly short as well as out of the interior of your roadster. You might consider adding a fusible link at the connection to the starter solenoid.
Last edited by Frisco; 07-08-2008 at 05:06 PM. Reason: added additional info about fusible link
Old 07-08-2008, 05:57 PM
Thanks - thought so - but wont use a fusible link - in anything. I will have a Maxi-Fuse in that line though.
Dave W
Irelands child
Old 07-08-2008, 06:58 PM
T-bucket23's Avatar
Wiki Edits: 26
I am worried that you may be putting a lot of current through a connection point with a lot of wires and the potential for corrosion or loosening up. This could cause heat it the connection becomes loose or dirty.
With the charging wire the fewer connections the better in my opinion
CHet
Old 07-09-2008, 07:23 AM
Chet - There will be only the two connections on that 3/8" post. One is used intermittently, the starter, and the second during engine operation. I use star locks on these heavy gauge wires and very good ring terminals to ensure good contact as well as a silicone electrolytic grease.
Dave W
Irelands child
Alternator excitor wire voltage guba_unus Electrical 9 05-01-2008 05:30 PM
3 wire alternator hookup GCD1962 Electrical 10 04-21-2008 09:29 PM
One Wire Alternator?? budthespud Electrical 9 11-24-2007 09:06 AM
Wiring a 1 wire alternator and starter 71novactb Electrical 7 02-09-2007 10:14 PM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 03:47 PM
