One Wire Alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2009, 08:24 PM
One Wire Alternator
I'm almost finished with my street rod. I have a one-wire alternator and my battery is in the trunk. Do I need to run the wire all the way to the positive battery terminal or can I connect it at the post on the starter solenoid (GM) where the positive cable from the battery is connected? Also, what size wire is required?
Thanks for any help!!!!!
Paul
Old 10-09-2009, 09:24 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
You could connect it at the starter, but use 6ga or better to run from the alternator to it. During deep cycles of discharging, you may have to put a charger on the battery to bring it up or wa`i1t longer for the battery to fully charge.
Old 10-09-2009, 09:47 PM
One Wire Alternator
Thanks for your reply. Would it be better to go ahead and run the wire to the battery instead? If so, would 6 ga. be sufficient? The car has no radio, power windows, etc. Just lights, turn signals, etc.
Old 10-10-2009, 12:40 AM
Last journal entry: It's getting there
One Wire Altenator
I ran the positive cable to a power block on the firewall and ran the altneator wire to the block. Pulld a block off of a Chevy Pick-up ay yhe local Pick-N-Pull. Works great. No problems.
Alternator excitor wire voltage guba_unus Electrical 9 05-01-2008 04:30 PM
3 wire alternator hookup GCD1962 Electrical 10 04-21-2008 08:29 PM
One Wire Alternator?? budthespud Electrical 9 11-24-2007 08:06 AM
Wiring a 1 wire alternator and starter 71novactb Electrical 7 02-09-2007 09:14 PM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
