one wire alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2006, 04:45 PM
one wire alternator
i have a 67 chevelle with a 3 wire alternator, 1 batt. and a 2 wire plug that plugs into the alternator that is labled r and f, i bought a 1 wire alt. my question is how do you convert it over and get rid of the voltage reg.?
Old 04-03-2006, 04:54 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Simple..
Assuming you have already installed a one wire Alternator..
Just run the wire from the Alternator to the big bolt on the starter solenoid Via a proper fuse link and / or Maxi fuse , use a 10 gauge wire.
As for the EXTERNAL Regulator, just Disconnect it, Be sure any wires on the BATT terminal Remain connected together, (they will power other parts of the car..) and insulate, mark, cap and tie them off..You may also have to pull the Charge lamp out of the socket.
Doc
Last edited by docvette; 04-03-2006 at 04:57 PM. Reason: Bumbling bigthumbitis..Most used key..backspace!
Old 04-04-2006, 12:28 AM
reply
do i need to jump any wires from the alt. batt post to the #2 terminal on the alt.
let me get this right, from the batt to the starter and from the alt batt post to the starter, disconnect ext reg and tie all the wires going to the batt on the reg.
Old 04-04-2006, 12:33 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
I thought you said this was a "one Wire " Alternator??
If not you have a 3 wire internally regulated alternator ..a horse of a different color. Yes jumper that wire over...
The rest is correct EXCEPT DO NOT forget a fuse link or Maxi fuse on the batt wire..or you may be sorry later on..
Doc
Old 04-04-2006, 12:45 AM
reply
i bought a powermaster alternator and it said it can be used as a 1 wire or a 3 wire alternator
Old 04-04-2006, 12:48 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Oh..OK, KEWL..
Then follow the instructions for the one wire config..
The rest of the hook up posted is still the same.
Doc
Old 04-04-2006, 12:50 AM
reply
thank you ill hook it and i should be good to go
What's the proper way to wire an alternator? 70bird Electrical 18 08-14-2010 12:24 PM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
4 wire alternator?!?!? ProjectSuperNova Electrical 8 02-14-2005 03:11 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 03:59 AM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
