one wire alternator convertion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2013, 11:55 AM
I have a question that i am sure is been answer many times, I have a 1969 jeepster commando V6 225 buick engine, it still has the original alternator/ generator and point distributor with with coil the the previous owner has too many wires cut and so on, I would like to rewire it , i want to put a single wire alternator from my 69 camaro, i know one of the wires will go to the batt. there is also two spade connectors does one goes to ignition sense to charge the alternator, and once i done with this , do i get rid off the old valence resistor, and the regulator, and how to i wire the coil, if someone can sent me a diagram it will be nice, i am not an expert at this , but i can hold my own. thanks, one last thing i will be running an external gauge sinse there is none.
1 wire or 3 wire alternator??? oldguy829 Electrical 34 03-12-2013 10:47 AM
wire terminal broke off 2-wire alternator bullheimer Electrical 3 10-11-2009 10:22 AM
One-wire to 3-wire Alternator change nova69 Electrical 2 09-05-2005 07:18 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 03:59 AM
2 Wire to 1 Wire Alternator bluesman123 Electrical 8 02-04-2003 12:06 AM
