One wire alternator to starter post? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 02:48 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
Getting to work on dropping the engine in next week (I think)
I decided to run a powermaster 140 amp 1 wire alternator. The battery is in the trunk. I ran a secondary number 4 to the interior fuse panel, but it only has a 60 amp fuse. It runs the subwoofer amp, all the main car electrical systems, lighting radio, etc.
The wire I have running from the battery (in the trunk) to the starter is unfused #1 Ga. I was thinking of running the amp wire to the battery post on the starter.
Does anyone know of any potential problems in doing this?
Old 05-30-2008, 02:52 PM
malc's Avatar
Living At The Speed Of Life
Have you got a remote starter solenoid in the trunk ?
If not you have a potential disaster as the starter cable will be live.
Check this out from MadElectrical and check it against what you have.
Old 05-30-2008, 02:57 PM
malc's Avatar
Like this, my rear mounted battery and solenoid.
Not quite finished at this stage.
Old 05-30-2008, 05:16 PM
FEDDO's Avatar
that looks good. nice workmanship. Where is your battery shut off?
Old 05-31-2008, 09:33 AM
Ripped's Avatar
Nice set up, I like the soleniod box.
I ran my old roadrunner battery in the trunk conversion without any soleniod.
I don't see any problem, if you run the wire correctly. Worst case scenario, you can get large fuses from marine suppliers ie 300 amp +
I think the newer chrysler 300 have the battery in the trunk. What do they use?
Old 05-31-2008, 01:15 PM
malc's Avatar
"It makes good sense to put the START’M UP solenoid next to the battery (in the rear)–to avoid routing a “full-time battery live” cable all the way forward to the starter. (If a “live” starter cable ever became shorted, a fire or battery explosion would be likely.)"
I would´nt tempt fate.
Old 05-31-2008, 06:33 PM
406 bug's Avatar
9.82 @ 139mph
some will not agree, but the alt. line should go to the bat. (bat. should provide prower the elec. system ; not the alt. Just my opinion.
Old 06-01-2008, 12:18 AM
malc's Avatar
Just my opinion.
Based on what facts ?
The alternator powers the electrical components, the battery starts the car and acts as a cushion when more items are used until the alternator catches up.
Read through this.
Old 06-01-2008, 01:07 AM
SSedan64's Avatar
It would be better to run the Amp wires to the battery. The battery acts as a noise filter. You may pick up some unwanted electrical wine/noise.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
How do I wire a 3 wire alternator when I used to have a 1 wire alternator??? billsbird Electrical 7 09-05-2007 10:01 AM
starter wire? yoyomo Electrical 1 08-24-2004 08:32 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 10:59 PM
