One-wire experiment gone bad - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 05:46 PM
Over the winter I freshened the 351W in my Mustang, and in the process I went to a GM one-wire alternator. The problem is that when the engine comes up to temp, and the electric fan comes on, the engine sputters and dies - like there isn't enough juice left to power the ignition system. Can I go to a 3-wire setup by running switched power to the #1 regulator terminal and a jumper from #2 terminal to Bat on the alternator? It appears the one-wire just doesn't have enough at low rpm to do what it's supposed to do. Help desperately wanted. Thanks in advance.
Old 07-19-2005, 06:30 AM
Check this site out it may explain why your alt is not reading the need amp load.
http://www.madelectrical.com/
Ed ke6bnl that why I went with a three wire over a one wire without a sensing lead. Ed ke6bnl
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Where the resistor wire supposed to go ? Olds 69 Electrical 33 02-08-2005 02:10 AM
Ground Wire Getting hot when trying to start Double0svn Electrical 10 08-14-2004 10:55 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 04:39 AM
how bad is it to ride on bad akm Suspension - Brakes - Steering 5 05-13-2003 10:28 PM
