one wire gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2012, 02:25 PM
beachbum0's Avatar
one wire gas tank
I am assuming that my one wire, on my behind the seat gas tank, in my 69 chevy pick up is the one that hooks up to gage and the tank is grouded with the seven bolts that hold it in place. In any case I am going to check the sending unit and the wires. My gage also reads empty.I was almost certin that when I put gas in to break in engine it read the fill, about 1/4. Im wondering if it can work some of the time and not?
Old 07-07-2012, 04:15 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Using an Ohmmeter read the resistance between the single wire and ground.
Don't depend on the bolts for a ground. Connect direct to the sender body.
You should read anywhere from 0 ohms for an empty tank to 90 ohms for a full tank. If not replace the sender.
vicrod
Old 07-07-2012, 05:47 PM
beachbum0's Avatar
Thank's ill get a ohms meter and do that.That was the fastest and easyest fix on my truck.Everthing I have done to my 69 is realy helping me for a 62stepside restoration, will be back
Is this Gas Tank neck bad? Tank? Clean it? Leave it? gotmud Engine 2 07-06-2011 01:43 PM
Gas Tank Sending Unit Ground Wire Question daveh Hotrodders' Lounge 2 03-30-2007 12:14 PM
which wire is what on my gas tank? Fordy8man Electrical 2 10-02-2004 02:56 PM
gas runs back to gas tank... 66nova guy Engine 7 12-28-2003 05:35 AM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 06:13 PM
