one wire / three wire, alternator hookup - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2003, 12:08 AM
New Member
so....
after dumping a crate motor & turob 350 into my new project truck, the last thing i'm polishing off is the wiring. i got a new DelcoRemy three wire alternator and a new interstate mega battery. all is well, except i think my wiring is off. the truck will not recharge the battery when it is idle. it will only charge when i'm cruising down the road.
the setup:
** the alternator BATTERY post has a 14 gauge wire going over to the battery POSITIVE terminal
** the #1 and #2 on the alternator are two 14 wires twisted together, connected to the nearby alternator BATTERY post
is this right? or am i gonna start frying diodes or whatever?
since i bought the alternator from kragens i can just return this one and get a new one if necessary if i've fried it, but it still seems to work ok minus the no-charge-at-idle problem. i guess i heard that if you wire the alternator off or something it can permenantly fu*k things up.
**********more info: when i have the truck running, and disconnect the #1 and #2 from the alternator BATTERY post, the engine starts revving way higher. i'm guessing this is from the regulator in the #2 wire not being in the power loop. yay or nay? ***********
wavin the SOS flag, --tommy
Old 10-24-2003, 03:59 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
I think you may have it wired wrong, bro' ... check out this article -- it discusses the diff between 1-wire and 3-wire alt's, but if you read on it shows wiring diagrams, etc.:
MadElectrical
Good luck!
Alan
54 Chevy Pickup
