only my lights work....help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2005, 11:09 AM
406 six speed
Just put in a new manifold on my wagon.Went to go start it and nothing!not even a click.I have power to the headlights and my door selenoids but thats it.No wipers radio , interior lights ...my ignition doesnt even buzz.i checked everything and cant find the problem.I dont know what turns on the ignition or the accesories, some kind of relay?If it is a relay where is it on a 78 malibu wagon and how do i test it?I need help and quick.
Old 05-27-2005, 11:53 AM
my alter ego
Intake manifold? if so check the wires from the alternator.
Old 05-27-2005, 12:03 PM
406 six speed
all connected.Theres no juice after the fuse box except to the lights and anything else thats direct to the battery.
Old 05-27-2005, 12:10 PM
DoubleVision's Avatar
Check the ground, if it`s connected to the alternator bracket, I`d reroute it directly to the block. While I doubt this is your problem, it`s likely at some point a hot wire got grounded while you were swapping intakes and it popped the fusable links. The fusable links are down by the starter, and they usually have a shield around them that`s bolted to the bellhousing. Check all the wires, make sure none are under the intake, or the valve covers. If all looks okay, then the fusable links are the last place to check, if they did pop, replace them, you`ll have to splice into the wire, and I would recommend the use of heat shrink butt connectors, do NOT, I repeat, DO NOT run a direct connection without fusable links! if the problem that caused them to pop is still there and you connect the battery you have instant fire. Next time remember this tip, anytime your doing any kind of work like a intake swap, always disconnect the battery. I learned this lesson when the same thing happened to me on my 79 malibu classic.
Old 05-27-2005, 12:14 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
No relay on the Malibus.Do you think you could have hit the ground strap that is connected to the firewall? It hooks to the firewall right behind the firewall.Check all your grounds,and hot leads on the battery.It is going to be in the grounding circuit somewhere.If you have lights and nothing else.Quick test here.Take a set of jumper cables,for jumping a battery.Attach one end to a good frame ground,attach the other ground clamp to the alternator bracket or something that is a good dependable engine ground,see if it fires up.If it does just double check all your wires and make sure they are tight,or the terminals did not come loose.
Double Vision,did not even think about the links,another good idea there.It is going to be something simple.
Old 05-27-2005, 06:40 PM
camaro409's Avatar
YOu KnOw IT
dang links
The fusable links got me today ....what a pain all that swearing for nothing
Old 05-27-2005, 07:04 PM
406 six speed
thats what it was.....
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 09:42 PM
Social Security. crazy larry Hotrodders' Lounge 48 04-27-2005 11:12 AM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 02:59 PM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 04:20 PM
my newborn crapped his die-dees: l.e.d lights all blew up bullheimer Electrical 4 08-16-2002 09:44 AM
