OOOOPS...!!! 454 flywheel.. wrong part???
454 flywheels do have balancing weights on them right?
I just discovered that my engine is running with a regular non balanced 350 flywheel, but I haven't noticed any strange vibrations. my engine comes from a 1984 C30 pickup, did this engine come from the factory with a balanced flywheel? are all 454's externally balanced? the previous owner must have changed it and didn't noticed the difference. I'm doing a cam swap and some minor porting before it goes into the engine bay of a '46 chevy, will bolt to a modified TH350 with a 2.200rpm converter and 4.11 rear end. |
Far as I know they`re external balance on a 454.
If a non external balanced job was installed it wouldn`t have ran very long before it destroyed the thrust surface. One time when I happened to be in the same place where a guy swapped on a new flexplate on His 400 small block that was a 350 unit, he got out of the driveway and about 60 yards away before it started knocking. In this case do you mean flywheel as in for a stick shift or flexplate for a automatic? |
my bad, it's a flexplate, automatic transmission.
it doesn't have any weigths, it's a regular 350 unit for sure. but the engine is not damaged, maybe I stopped it just in time... |
Be aware that there are also several different 454 flexplates. So be careful to match the years. Later flex plates are more weight. ALL WILL BOLT UP TO A TWO PIECE OR ONE PIECE SEAL CRANK.
thanks amigo. |
| All times are GMT -6. The time now is 07:48 PM. |
