OOOOPS...!!! 454 flywheel.. wrong part??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 08:27 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
454 flywheels do have balancing weights on them right?
I just discovered that my engine is running with a regular non balanced 350 flywheel, but I haven't noticed any strange vibrations.
my engine comes from a 1984 C30 pickup, did this engine come from the factory with a balanced flywheel? are all 454's externally balanced?
the previous owner must have changed it and didn't noticed the difference.
I'm doing a cam swap and some minor porting before it goes into the engine bay of a '46 chevy, will bolt to a modified TH350 with a 2.200rpm converter and 4.11 rear end.
Old 07-12-2011, 12:22 AM
DoubleVision's Avatar
Far as I know they`re external balance on a 454.
If a non external balanced job was installed it wouldn`t have ran very
long before it destroyed the thrust surface. One time when I happened
to be in the same place where a guy swapped on a new flexplate on
His 400 small block that was a 350 unit, he got out of the driveway and
about 60 yards away before it started knocking.
In this case do you mean flywheel as in for a stick shift or flexplate for a automatic?
Old 07-12-2011, 07:56 AM
Augusto's Avatar
my bad, it's a flexplate, automatic transmission.
it doesn't have any weigths, it's a regular 350 unit for sure.
but the engine is not damaged, maybe I stopped it just in time...
Old 07-12-2011, 09:05 AM
BOBCRMAN@aol.com's Avatar
Be aware that there are also several different 454 flexplates. So be careful to match the years. Later flex plates are more weight. ALL WILL BOLT UP TO A TWO PIECE OR ONE PIECE SEAL CRANK.
Old 07-12-2011, 04:34 PM
Augusto's Avatar
ok, I'll take that in consideration when ordering a new flexplate, mine's a two piece seal.
thanks amigo.
Is it wrong to put a Fiero part in a Vette? Jake_Dragon Hotrodders' Lounge 14 04-10-2009 08:38 PM
Part # for 454, 4spd Flywheel Fastest65 Transmission - Rearend 3 01-21-2009 09:12 AM
Exhaust oooops ? DrBee8457 Engine 1 11-17-2006 09:09 AM
Oooops!!!!! RetroJoe Hotrodders' Lounge 4 11-19-2004 06:16 PM
wrong flywheel markiemyster Engine 6 07-30-2003 03:52 PM
