Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - OOPS can this be fixed
Old 08-10-2010, 07:41 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
When these break I`ve used a pick tool and just spin it out. Trying to use a easy out was a big mistake and now you see why. I`ve also removed them with a small flat tip screw driver. You may want to take it to the machine shop and let them get it out. More than likely the hole will have to be retapped if the threads got damaged and they likely did.
