OOPS can this be fixed
Ok heres the deal I bought a 350 from a friend and why we was pulling it out the sending unit got caught on something and broke off flush in the block so then we took an easy out and tried that and it broke off to,so the question is how can I get this out and can a machine shop do it if so how much could it cost to get it out.
o and forgot to mention it was the oil pressure sending unit
It can be taken out . Try a small chisel to the edge of the easy out to see if you can loosen it enough to jiggle it out. Its a pretty hard chunk of steel so it may chip a little . try to loosen it by tapping it in the direction that the easy out will back out.If it is a square fluted design all you need to do is get it loose and you might be able to lift it out. Worst case scenario would be to drill out the broken stem of the unit by drilling a series of holes all the way around it so you can gain enough clearance to knock it loose in its hole.I doubt you will have to go that far but if so it can be kind of tediuos to perform.
| I fixed it! :) but now having trouble with lights | Kayleme | Electrical | 4 | 08-15-2009 09:01 AM |
| TH400 Can I replace a fixed yoke with a slip Yoke? | Double_v23 | Transmission - Rearend | 4 | 08-07-2008 06:31 AM |
| Chevy Fixed Yoke? | Triaged | Transmission - Rearend | 6 | 06-12-2008 11:43 PM |
| Fixed Steel Bladed Fan Info | sixty5 | Engine | 1 | 07-15-2003 10:39 AM |
| 8.8 rearend bent (can it be fixed?) | shagginwagonvic | Transmission - Rearend | 2 | 04-11-2002 02:40 PM |
