Oops, GM 5.0L and 5.7L intakes are they the same? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 12:09 PM
Gearhead forever's Avatar
I'm putting a 1995 donor 5.7L back together (in its factory configuration) and putting it into my '87 Chevy P/U I ditched the original 305 except for the intake set up. I didn't label either intake, but seem to think the 5.7L used the intake with casting #'s W2, 14102182, 6248. The other intake has a W6, 10166133, 5296 numbers cast in. Both intakes look identical as do the throttle bodies. (Same bore sizes)
Does anyone know if either of these are 5.7 specific? (I had originally planned on building this motor up, but with the recent economy she's going back together as is....for now)
Thanks in advance.
Old 12-28-2008, 02:01 PM
bigolblackie's Avatar
I believe its the internals crank,bore stroke etc. thats different,not the intake manifod. I beleive you can use either intake,but Im no expert like others on here,I could be wrong.
Old 12-28-2008, 02:47 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
They are different intakes, but they are interchangable. I would use the ones that most closely match the ports on the head (just measure width and height) and the one that is the tallest. That would theoretically flow more and be a better match for the 5.7. Since they're both factory castings, they'll both be mild-flowing intakes, and unless you've souped up the rest of the engine, either one should be fine.
Old 12-29-2008, 07:51 AM
I never thought to compare the height or port sizes.
The motor isnt hopped up at all at this point. Maybe a mild cam later. If I change the intake later, it will be with a pair of vortec heads anyway.
Thanks
Old 12-29-2008, 09:52 AM
curtis73's Avatar
Wiki Edits: 16
I should add...
The throttle bodies are the same, but the injectors are different between 5.0 and 5.7. Make sure you have the right injectors.
GM 5.7L crate engine suffix codes SCRUBBY Engine 2 11-30-2009 04:36 PM
GM temp sender resistance 1991 4.3L 5.0L 5.7L fast68 Electrical 1 07-03-2008 07:24 PM
1989 GM 5.7L TBI - Hard Starting Help! Rambo_The_Dog Engine 6 12-04-2006 01:42 AM
