Oops...head gasket upside down? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2012, 08:50 AM
Silver Surfer's Avatar
Advanced User
Last journal entry: Test Drive (finally)!
I got the heads on my SBC last night and afterward I noticed the dipstick hole was half covered up. After a closer look, it would appear there is a cut out that would have lined up perfectly with the hole if I had put them on the other way. DOH! Is this going to be an issue?
These are the gaskets in question.
Clevite Engine Parts 5746 - Clevite Nitroseal Cylinder Head Gaskets - Overview - SummitRacing.com
Thanks!
Old 10-20-2012, 09:32 AM
S10 Racer's Avatar
http://www.warsprints.com
There should have been stamping that says something like "This Side Up" or similar. Install them with the solid metal fire ring against the block and the crimped side towards the head.
Old 10-20-2012, 09:52 AM
Advanced User
I can appreciate that, but what do I do now?
Old 10-20-2012, 10:17 AM
S10 Racer's Avatar
As long as it's not an LS motor, you should be ok. Some engine builders install them upside down for aluminum heads and right side up for steel heads or vise versa (I can't remember).
Old 10-20-2012, 10:32 AM
Advanced User
No LS, just a Gen1 SBC 350. I looked over the gaskets and did not see an UP mark or any indication like that. The holes all seem to be symmetrical and line up just fine. There is a fire ring on both sides of the gasket, but there are some other metal (?) types "plates" around some of the water and oil holes. Since these are "nitro seal" gaskets, I assume they have really good sealing around the water and oil holes though.
Some googling showed other horror stories about over heating and partially blocked oil passages, etc. Not sure if its the same motor or what though. But yes I also uncovered info that said for aluminum heads, you need to use them upside down.
Old 10-20-2012, 12:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks!
The main problem will be cutting away the gasket overhanging the hole so you can install the dipstick tube.
If the gaskets were torqued down, I wouldn't recommend flipping them around. So it's run them as-is or replace.
Now, the gasket will seal OK, but after the previous issue w/the gaskets trying to stick when you did the mockup, you might as well replace it.
Old 10-20-2012, 12:47 PM
malc's Avatar
Born To Be Mild
I used those same gaskets the last time my heads were reinstalled.
There is no up side indicated like Fel Pro´s have, both surfaces are the same.
I cannot see where the dipstick issue comes in, the dipstick tube hole is located low on the block not the heads.
BTW, those gaskets have a very sensitive surface, they scratch/mark very easily.
Old 10-20-2012, 12:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good point. Somehow I thought of the oil pan gasket when he was posting about the head gasket. Same deal though. For a $20, replace if there's any question.
Old 10-20-2012, 12:59 PM
malc's Avatar
Born To Be Mild
The previous set I removed had done their job perfectly.
Removal was destruction of the gasket, as they stick like baby poo to
a blanket.
I also have aluminum heads, no issues there either.
Should I use a gasket sealer on a .015 shim head gasket? Caprice Sleeper Engine 5 08-23-2012 07:46 AM
Head gasket thickness, Gasket or Shim? rollie715 Engine 6 04-25-2012 03:15 PM
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 01:12 PM
Mr Gasket Ultraseal Head Gasket's 406 ss monte Engine 4 05-03-2008 08:19 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
