Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oops, i traded....!
Old 12-03-2012, 07:50 PM
bygddy bygddy is offline
Proud LOSER
Originally Posted by F-BIRD'88 View Post
Sell them back to the guy for $150. I can lay out a simple low cr stock short block supercharged 350 build plan for you that does not need big gears. Makes silly big power and cruises. No OD required.
Based on the Weiand 177 blower and hyd cam and Summit/Brodix heads. (3.36 to 3.73 gears are fine).
What converter do you have?
Start by bolting the 177cid blower on what you got, at low boost. Upgrade as it comes along.
It all fits under the hood on that car.
I have that b&m for the vette that I never put in, 3000 stall, well I will put a feeler out and see if i can flip these heads and find some decent ones used.....this thing is goofy and has remote oil filters, 2 of them mounted high up on the fire wall with braided line to an adapter, no idea why....31" tires is gonna want more gear then normal tho....I will start looking around for a weiand 177 used and if not start saving lol....
