Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oops, i traded....!
  #26 (permalink)
Old 12-05-2012, 08:54 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The muthr thempr and BIG MUTHR THUMPR cam actually make very good power
when used in a high compression ratio motor with head flow and LOW restriction Exhaust!.
They need big gears and converter stall and correct distributor setup.
The engine must be able to rev up === valve springs and port flow.
High compression ratio = 's 10.5:1 for sunoco 94 gas.
needs 5.38:1 gears for a 31" tall tire and a 3500++stall
