Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oops, i traded....!
  #31 (permalink)
Old 12-05-2012, 11:08 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If you want to try the smaller thumpr cam for grins in that motor, with the stall and gears, degree it and move to a 100° intake C/L
.050" timing check points (checked using a solid lifter) 13.5 -- 33.5(intake closing point) 54.5 --6.5ex
227 241 @.050" 107° lSA 100° in 114°ex installed C/L's
Lock out the distributor mech adv system (full locked 34 to 36deg timing).
You can retain and use the vac advance (ported)
use a 4.5' power valve or 4" step up spring (eddy)
5.13++ gears. 3000+stall
