Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oops, i traded....!
  #33 (permalink)
Old 12-11-2012, 03:59 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
What is the oil pressure at 2000 rpm? that is the critical spec.
A simple compression test will tell the general health of the motor too.
Should run good with those changes. Don't put 2.02's in the 416 heads. 1.94 is best.
You can block off the egr heat riser passages by filling with old melted down pistons.
Post the results when you get it done.
