Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oops, i traded....!
  #34 (permalink)
Old 12-11-2012, 10:39 AM
bygddy bygddy is offline
Proud LOSER
Originally Posted by F-BIRD'88 View Post
What is the oil pressure at 2000 rpm? that is the critical spec.
A simple compression test will tell the general health of the motor too.
Should run good with those changes. Don't put 2.02's in the 416 heads. 1.94 is best.
You can block off the egr heat riser passages by filling with old melted down pistons.
Post the results when you get it done.
At 2000 its around 30 -35 psi.
No no, will use valves from the old 882 heads i pulled off the vette, stock 350, and use the guide plates and screw in studs and springs from the circle track 882's I picked up. The felpro 1205 are blocked at the heat riser....
