Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oops, i traded....!
  #35 (permalink)
Old 12-11-2012, 10:44 AM
bygddy bygddy is offline
Originally Posted by bygddy View Post
At 2000 its around 30 -35 psi.
No no, will use valves from the old 882 heads i pulled off the vette, stock 350, and use the guide plates and screw in studs and springs from the circle track 882's I picked up. The felpro 1205 are blocked at the heat riser....
Although there is a shop in Montreal that is selling dart alum heads fully assembled for 950$, 200cc....so may do a little more researche and find out which heads they are and if its worth it.....they are only a couple hours away at the most. If they are legit, and 64cc chambers, I will run the 1094 head gaskets, and be coming back to you for much larger cam reccomendation to really use a big head like that.
