What is the oil pressure at 2000 rpm? that is the critical spec.
A simple compression test will tell the general health of the motor too. Should run good with those changes. Don't put 2.02's in the 416 heads. 1.94 is best. You can block off the egr heat riser passages by filling with old melted down pistons. Post the results when you get it done. |
No no, will use valves from the old 882 heads i pulled off the vette, stock 350, and use the guide plates and screw in studs and springs from the circle track 882's I picked up. The felpro 1205 are blocked at the heat riser.... |
Although there is a shop in Montreal that is selling dart alum heads fully assembled for 950$, 200cc....so may do a little more researche and find out which heads they are and if its worth it.....they are only a couple hours away at the most. If they are legit, and 64cc chambers, I will run the 1094 head gaskets, and be coming back to you for much larger cam reccomendation to really use a big head like that.
Nice truck, but I'm sure you'll find it's not a "sedan delivery". It's a Chevy panel truck. Sedan deliveries were based on a station wagon body and chassis with a delivery door on the back, while panels were truck based on a 1/2 or 3/4 ton truck.
Thanks dave |
Then don't choose and or buy a camshaft until you have the cylinder heads in your hand.
is this a new aluminum cylinder head? Remember the SHP head is the cheap red haired step child brother of the Dart Platinum Pro 1 head. You get what you pay for. Lots of really good heads to choose from in the $1000 price range. www.brodix.com www.profilerperformance.com #3670 This car is a tank! Last edited by F-BIRD'88; 12-12-2012 at 07:37 PM. |
Buying parts that are for sale.
you need to try to avoid falling into the trap of collecting a bunch of stuff because it is easy or avaiable and then adjusting your plan to suite the the parts. You will end up with a much better result for the money spent by developing a good build plan and then buy the parts that fit the plan. Even if that means waiting. The local used-for sale Kijiji/craigslist part that does not fit your plan is not a good deal. EG: buying a 3000 stall converter because it was for sale, even thou you wanted a more radical motor ( big cam duration/tunnel ram) that needs a converter with a higher stall. Same with gears. Same with cylinder heads. If you want a 500hp performance result, don't buy 325HP parts. You need to define your performance goals better, before buying parts. One of the benefits of the long cold snowy Ottawa winter is you got lots of time to create a good plan. A good Hot Rod build aways needs a good plan. |
Dave |
Wait until you have the heads etc. One of the biggest mistakes people make is rushing out and buying a cam
and ending up with the wrong cam for the job. The cam choice is a critical element. It sets the whole nature of the engine. and how the car "drives". The Lunati street 401A3LUN solid cam is still a good overall choice for where you're headed. Its a nice "street cam" Something in that range is good. possibley with more lift or rocker ratio with the dart heads. If that is your head choice then they will benefit form some port cleanup as all as cast heads do. possible Crane F-280-2 cam #114681 (or a custom grind variation of it) Crane F244/3454-2S-6 possibe single pattern version (crane custom grind) Lunati solid Voodoo #60141 ( or Lunati custom grind variation) With what you got (3000 stall) and the purpose I would not go bigger than these cams. All need a good exhaust system. use a performer RPM and 750carb A street tunnel ram + eddy carbs can still work. These Dart heads come with different spring packages. "K1 K2 etc" K1 is usually the stock entry level diameter "hyd cam" springs. Get the spring package that matches your cam choice. A Voodoo Solid street roller would be cool. Lunati #60132 Last edited by F-BIRD'88; 12-12-2012 at 08:45 PM. |
Does this speed shop have Brodix heads?
Something to consider if you are going to buy speed parts http://shiptotheborder.com/ogdensbur...rockville-area http://www.jegs.com/i/Lunati/638/60141/10002/-1 These cams need good springs Usually a "K2" spring package. New Lunati Part number 30120741 Lunati Cam grind number CS V8 V276S10 "Jegs" Profiler "USA head" http://www.jegs.com/i/JEGS-Performan...ductId=1593012 Last edited by F-BIRD'88; 12-12-2012 at 09:11 PM. |
| Traded The Turbo S-10 For New Ride | TurboS10 | Hotrodders' Lounge | 15 | 06-09-2010 02:27 PM |
| Oops.... | screamin340 | Suspension - Brakes - Steering | 1 | 04-21-2007 10:03 AM |
| oops | adrock430 | Body - Exterior | 1 | 02-13-2005 03:29 PM |
| Oops! | NAIRB | Garage - Tools | 3 | 12-06-2004 11:16 PM |
