oops, i traded....! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2012, 07:13 PM
oops, i traded....!
Just got home, guy mailed this morn bout my vette. Came and saw, and straight trade....called my buddy with a tow truck, and off we went. 1940 chev sedan delivery, tubbed, narowed 9", mild 350, all steel, tub job is beautiful, tires are new, nova front clip, power everything, even has heat! Nice 6 point cage, etc etc, needs minor elec stuff, tach and volt guage and signals not working. 010 block, not sure of heads yet, weiand intake, has lots of oil pressure and runs well, haven't driven it really yet so don't know how slow it is but I suspect plenty slow lol....will work on that over the winter, I'm thinking 456 gear, tunnel ram, big solid cam, and hopefully some decent used heads. Should be fun, for the less then 3500 I had in my lumpy vette I think I did OK....I do have to stiffen up the rear end, soooft springs......
Old 12-02-2012, 07:48 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Good trade! Sounds like you done good
Old 12-02-2012, 07:50 PM
vinniekq2's Avatar
nice truck,have fun with that one
Old 12-02-2012, 08:03 PM
I didn't hide anything with the vette, but honestly feeling more then a tad guilty....he was asking 18000, has an appraisal for 26, and on a good day my vette is a 4000$ car.....ah well....kids friggen love it, will have to relocate gas tank to install a small rear seat for them, .....and man does it run good, gonna be a shame to take the motor apart lol....
Old 12-03-2012, 03:44 AM
Last journal entry: 50 Ply wagon
Unless you are gonna do some serious racing, why tear the motor apart .If this motor runs as well as you say and all you have to do is minor stuff, then leave it alone and drive it. More HP means more gas, more heat ,so you may have to upgrade the radiator and finally more HP means more headaches.
I did the race car for the street thing. It is fun but its also a pain in the ***. Have fun with the car and just drive it.
Old 12-03-2012, 12:22 PM
How fast is fast enough?
I'd swap in a OD trans if it doesn't have one already. That's something you'll really appreciate on the street.
Old 12-03-2012, 03:20 PM
Depends on the gear, which honestly I have no idea right now, haven't driven it yet lol.
Old 12-03-2012, 04:59 PM
F-BIRD'88's Avatar
Yada Yada Yada
Needs a supercharger. You will enjoy that a lot more, on the street. OD is a big waste of money.
Old 12-03-2012, 05:28 PM
BigEd36's Avatar
Bygddy, you made a GREAT trade! If your wife decides she doesn't like this ride, I'll be more than happy to make sure you get your investment back, with even a little profit!
Old 12-03-2012, 05:29 PM
That's likely the plan, wanna get the elec sorted out, then pull the heads and see what I got, I picked up a set of very ported 882's with stainless valves, screw in studs and guide plates and comp springs for 100$, they were on a claimer 358 modified motor for one run, he won, the heads got claimed, then I bought em....they cc'd at 70, so depending on what pistons I find in this thing I may try and find a used blower somewhere and be happy with low comp lol.....throw my converter in it and some 411's or 456's and see how it works.......
Old 12-03-2012, 05:41 PM
F-BIRD'88's Avatar
Yada Yada Yada
Sell them back to the guy for $150. I can lay out a simple low cr stock short block supercharged 350 build plan for you that does not need big gears. Makes silly big power and cruises. No OD required.
Based on the Weiand 177 blower and hyd cam and Summit/Brodix heads. (3.36 to 3.73 gears are fine).
What converter do you have?
Start by bolting the 177cid blower on what you got, at low boost. Upgrade as it comes along.
It all fits under the hood on that car.
Old 12-03-2012, 06:51 PM
Unless you're like me and a day trip with 100 miles of highway each way is a usual thing on the weekends...
In stop and go traffic its next to useless, so I guess it depends on where you drive.
Old 12-03-2012, 07:50 PM
I have that b&m for the vette that I never put in, 3000 stall, well I will put a feeler out and see if i can flip these heads and find some decent ones used.....this thing is goofy and has remote oil filters, 2 of them mounted high up on the fire wall with braided line to an adapter, no idea why....31" tires is gonna want more gear then normal tho....I will start looking around for a weiand 177 used and if not start saving lol....
Old 12-03-2012, 08:00 PM
F-BIRD'88's Avatar
Yada Yada Yada
You won't find this stuff used, unless it is used up. Just buy new. You won't regret that. The blower itself will add a real kick
to the car. Both visually and big street go power. You can add to it later; as the need and funds allows. (heads etc).
Its really hard to beat supercharged power on the street.
It builds such a high torque motor that big gears are not really needed.
Think of it like having a 502CID BBC crate motor under the hood.
Big Block power and torque at a fraction of the price.
Old 12-03-2012, 08:15 PM
F-BIRD'88's Avatar
Yada Yada Yada
Well here the speed limit is 100KPH (62MPH) you can cruise @ 110-115 (70MPH)
The supercharged 350 gets the job done and cruises fine with a mid 3 gear.
Over drive does not add value to it. Just cost, better spent on the blower, it self.
A high performance motor does not like to cruise at a low low rpm.
On this car with 31" rubber you can cruise @2800rpm @75MPH with 3.55's and a th350 and 3000 stall.
It will GLH.
Traded The Turbo S-10 For New Ride TurboS10 Hotrodders' Lounge 15 06-09-2010 02:27 PM
Oops.... screamin340 Suspension - Brakes - Steering 1 04-21-2007 10:03 AM
oops adrock430 Body - Exterior 1 02-13-2005 03:29 PM
Oops! NAIRB Garage - Tools 3 12-06-2004 11:16 PM
