Open Headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2004, 11:46 PM
55ford's Avatar
Open Headers
Hi, I was just wondering, out of pure curiosity if it is illegal to run open headers?
Old 12-21-2004, 12:03 AM
poncho62's Avatar
Wiki Edits: 5
Here it is.......................probably is where you are too.
Old 12-21-2004, 01:58 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
It's illegal where I live.
It probably is where you live, because of the extreme noise level.
Old 12-21-2004, 02:06 AM
55ford's Avatar
Ok, Thank You Very Much.
Old 12-21-2004, 02:12 AM
Ghetto Jet's Avatar
if you have to drive this vehicle with open headers to a local exhaust shop, give the local police a call and let them know that's what you'll be doing. They will let you slide.
Old 12-21-2004, 03:53 AM
Darn close to open headers
Find some heavy wall aluminum pipe and run it off the collector/ reducers.
For cruisin, it will get you in the legal Db range
Old 12-21-2004, 03:54 AM
go this route
http://www.autospeed.com/cms/A_2291/article.html
and you can run them open at the track or when you think it's safe, but shut it down when the fuzz is on your back. or they also make headers with a dump tube you can bolt up manually.
Old 12-21-2004, 04:59 AM
holy mackeral taco502!
$$$$550 for butterfly valves in the exhaust to control noise!
It's less than $55 (?) for 2 pieces of heavy wall aluminum electrical conduit (Lowes/Home Depot)
Use some curved bend pieces if you can for less 1500rpm resonance
Plan "B", just to make noise, is the old fashion "choke cable control cut outs"( J.C. Whitney), they still make them.
Old 12-21-2004, 12:20 PM
not saying I've bought them, you're talking to a guy who has coat hanger holding his own exhaust right now. its just an option.
Old 12-21-2004, 02:43 PM
55ford's Avatar
Thank You All Very Much, I was wondering because I see alot of era specifics that look like they are running open headers. Also real quick o/t ? what about fenders on cars, is it illegal to drive w/o them.Thank You All Again.
Old 12-21-2004, 03:32 PM
MI2600's Avatar
Member# 3287
I had to drive about five miles to the muffler shop with open headers. That was enough for me...but I'm older...and probably a little deafer.
Old 12-21-2004, 03:52 PM
55 Ford
Bet what he's using on the pipes in your pic' are collector inserts.
A little hard to describe. It's a steel tube with rings of steel around it, usually 2-3 rings. Each ring has a number of holes in it that don't line up.
This lets some exhaust go directly down the center, the rest has to find it's way thru the holes in the disks which cancels out the noise.
You can find them on the Jeg's or Summit sites I bet. $80? + welding and fitting.
Same idea, more money are "rat-trap" mufflers. Kinda nice cause you can add/remove discs to tune the exhaust.
the no fenders, I've never done done it except on a bike and it ain't no fun in the rain!
Old 12-21-2004, 04:40 PM
check your local laws, I believe here in Oregon you can run w/out fenders if it aint raining, and if it is raining I think you can get away w/ just mud flapsor a small fender that just blocks the rear of the tire, (like truckers w/ the trailer)
Old 12-22-2004, 12:54 AM
willowbilly3's Avatar
Last journal entry: Body mods
I think you could adapt the EFE exhaust butterfly from a GM car as a cut out. they are vacuum operated and it shouldn't be much trouble to adapt them.
I think roadster style exhaust with some supertrapps might be cool but it would probably get old fast.
I have one friend who has an old T-bucket with a flatty that just has zoomys and it sounds so right, and not too loud either. Of course that is a flatty.
Old 12-22-2004, 03:36 AM
55 Ford
The car in your pic' I would call a "Laker" style.
The very first rods, in CA, raced for top speed possible on the salt lake flats.
The didn't have alot of power so the next best thing is no weight and streamline it so off with the fenders/bumpers/etc.
That's why the full disk wheel covers, "streamline" the wheels.
A stock model T winshield folds down, bet the windshield in your car pic' folds down to help with less drag.
Most were a weekend good weather race car. They did drive them to the flats outside LA with no fenders etc.
