Open Wheel Hotrod - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2011, 06:42 AM
Open Wheel Hotrod
I thought I was ready to build my first open wheel hotrod until I checked on the ol bank account. This led me down the path of building another Corvair powered 3 wheeler. (definitely open wheel) This is the third rendition of the same thing, only longer and heavier. I can add pictures of the build if anyone is interested. You must start with a 1964 or older (64's are best) Chevy Corvair. The automatic version is the way to go (cable shift) because no linkage is required. This complete rolling drive train comes out in a matter of a couple hours. From here you add a frame under the motor for the rear motor mount and add what ever motorcycle front end you want. (many to choose from at the motorcycle swap meets). This project can be put together for less than $3000.00 easily. Headers and intakes are also readily available. Use you imagination and have fun with it. Hope to hear from you.
Snake
Name:	64 Corvair Trike 01.jpg
ID:	61147   Click image for larger version
Name:	Corvair Trike 02.jpg
ID:	61148   Click image for larger version
Name:	Corvair Trike 03.jpg
ID:	61149   Click image for larger version
ID:	61150   Click image for larger version
Name:	Corvair less motor.jpg
Old 12-28-2011, 06:52 AM
delawarebill's Avatar
i did a VW trike Yrrrrrrrrr's ago
and turned it so the engine was in front... your sitting over the engine with rear/trans out back... very easy too... pull the plates that hold both rear axles and swap side to side.. that way the rear will turn backwards and u go forwards... back side is your gonna burn alot of pants cuffs that lay on the header in front....
Old 12-28-2011, 03:50 PM
Last journal entry: 41 chevy frame on the move.
Poor corvair
stefanP
two wheel hotrod joeshovelhead Hotrodders' Lounge 2 12-07-2011 10:08 AM
not a hotrod question, changing a wheel bearing TailGater Suspension - Brakes - Steering 3 04-18-2007 06:51 PM
hubless wheel: Swiss company re-invents the wheel Jon Hotrodders' Lounge 28 03-13-2007 01:36 PM
recovering a grant challenger wheel and painting the wheel itself gothrod87 Interior 0 09-14-2006 07:02 PM
Are chrome wheel plugs supposed to be loose in Weld wheel? shockers69 Hotrodding Basics 4 03-01-2006 10:05 AM
