Operation of Vacuum Switch for TCC Lockup
Another thread has discussed my attempts to incorporate a vacuum delay valve before the vacuum switch in my TCC lockup controls.
Without a delay valve, the switch activates and locks up the TCC. But with the delay switch in the line the vacuum switch does not activate.
I have traced the problem to the fact the vacuum switch does not hold vacuum. It bleeds off vacuum about as fast as the vacuum delay valve allows vacumm through. As a result the vacuum switch is only holding 2" of vacuum while the ported vacuum is pulling 13-15" at constant 45 mph with the delay valve in the line.
Maybe the vacuum switch is designed to have a slight delay of its own. Does anyone know if the vacuum switch is supposed to bleed off vacuum or is mine faulty?
John
