opinion needed on a combo, cam advice
here is my setup plan for the summer
74 351W stock internals
stock heads with mild port job 8:1 comp stock
edelbrock rpm air gap intake
1" 4 hole carb spacer
holley 670cfm carb
hooker comp headers
cam i was looking at getting from a bud is a comp XE268H cam
224/230 .509/.512
i'm thinking that i'll need to mill the heads and/or run thinner copper head gaskets to make the combo function better, but comp cams doesn't list a compression that the cam likes to have. Also, does anyone know if power brakes will still function without a canister or pump?
i'd like to be able to run 87 gas in the car, if that makes a difference - i'm willing to sacrifice the added power of compression if i can save on fuel, since canadian fuel is insane.
