Opinion on Optima Batteries - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-02-2003, 10:23 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Trees again you have inspired me! I don't know why I never thought of that myself.. Brain fade I guess...
Will the Optima fit on a standard battery tray? I think I can make a hold down out of u channel aluminum. Or do you use the nylon tie down straps?
Regards
Mark
  #17 (permalink)
Old 11-03-2003, 07:48 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Hey, Mark
I had to make my battery tray wider to accommodate the Optima ... and I use a piece of V-shaped aluminum for the hold-down (covered it with red electrical tape.
Alan
54 Chevy Pickup
  #18 (permalink)
Old 12-22-2012, 11:15 AM
I have an Optima Red top that I bought 4 1/2 years ago and it has been great but you should be aware that it does have vents. On the opposite side of the male posts you will see round protrusions with a poress material inside them. These are the vents. I learned this from the Optima factory yesterday. I also learned that when you mount the battery the factory recommends that these vents be mounted so that they are toward the top. Sooooo when they say that the battery can be mounted in any position this is true but you may experience some acid leakage at the bottom of the battery if you mount the battery with the vents at the lower part of the battery as I did.
  #19 (permalink)
Old 12-22-2012, 03:03 PM
malc's Avatar
Living At The Speed Of Life
Original post was 10-30-2003, 09:52 PM and the guy hasīnt been around here in years.
