Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Opinion on pinion angle
Old 04-07-2012, 01:59 PM
Dougie Dougie is offline
Swapping a small block Chevy into my 62 Studebaker Lark. Now that everything is installed my rear end flange is angled up 2 1/2 degrees relative to the transmission. I can buy shims for the rear end in 2 degree or 4 degrees. Should I use 2 degrees and have the rear end be up 1/2 degree or use 4 degrees and have it angled 1 1/2 degrees down relative to the transmission? This is a street car. I can't move the tailshaft of the trans upward due to clearance for the shifter (car has a narrow trans tunnel). And I can't lower the trans due to the design of the trans mount I had to fabricate. Appreciate your thoughts. Thanks
