Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Opinion on pinion angle
Old 04-07-2012, 09:31 PM
Centerline Centerline is offline
Wiki Edits: 49
delawarebill is correct. Angle the pinion the same as the trans output shaft except in the opposite direction plus or minus 1 degree. ericnova72's recommendations will work well for a car that spends most of its time on the drag strip, but for street driving you want the angles within a degree of parallel.
Centerline
HotRodsAndHemis.com
"Old age and treachery will always trump youth and exuberance." - Anonymous
