Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Opinion on pinion angle
Old 04-07-2012, 09:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Dougie
Swapping a small block Chevy into my 62 Studebaker Lark. Now that everything is installed my rear end flange is angled up 2 1/2 degrees relative to the transmission. I can buy shims for the rear end in 2 degree or 4 degrees. Should I use 2 degrees and have the rear end be up 1/2 degree or use 4 degrees and have it angled 1 1/2 degrees down relative to the transmission? This is a street car. I can't move the tailshaft of the trans upward due to clearance for the shifter (car has a narrow trans tunnel). And I can't lower the trans due to the design of the trans mount I had to fabricate. Appreciate your thoughts. Thanks
2 degree shims and a pinion snubber set to just touch the casting as far towards the transmission as you can (better mechanical advantage to resist the normal tendency for the pinion to climb the ring gear under acceleration) is one way to do it. I would use more 'pinion down' if it was a dedicated drag car.
Shope on suspension, etc.
