Sounds like a plan... Post pics when you get her done...
a question i have about it tho what would be a good charging setup cause other then the motor its also gonna be running a big system. I was reading the other day in lowrider about a dual battery setup but my problems with that are weight on the front and what kinda springs i would need to run? what do you think would be best?
Brandon |
Forget the "big system" and throw all of that money at makin the car hook and run...
I would still upgrade the alternator. A 100 amp unit should do fine as long as you don't overload it. The motor doesn't care as long as it supplies enough juice for the ignition, electric fan, electric fuel pump, and other accessories and to keep the battery charged.
Need more info - lethal is not very specific....... Cam specs, compression ratio, head design/chamber size, intake, exhaughst, ignition, ect., are needed to begin calculating this kind of stuff.
Not sure as to specific information yet.i havent really thought that much into it yet.itll most likely be stock for the most part with the addition of some edelbrock peices and a comp cam..im not looking forit to be downright insane seeing that it will be driven as a daily after im finished with it...as for the exaust hooker headers of some sort and all that running into summits glasspack sidepipes. im also gonna add an air gap intake along with an edelbrock four barrel with manuel choke. im thinking a 650.in my mind a 454 aint gonna need to much to smoke the tires on a light car like my camaro.Thats the best i can do for right now
| BBC 454 build ?? (long) | bobbypantera | Engine | 16 | 04-30-2005 11:04 PM |
| Opinions on selling my combo.. | draven | Hotrodders' Lounge | 12 | 04-10-2005 12:15 AM |
| Whats the best setup for a 454 bbc? | sugarmonkey | Hotrodding Basics | 1 | 02-22-2004 05:19 PM |
| 454 and Tire Wheel Combo on c-10 | iiiezekieliii | Engine | 1 | 01-29-2004 12:28 AM |
| BBC 454 COMPLETE 40,000 original miles,not needed F/S | fastco | Engine | 2 | 09-24-2002 07:34 PM |
