Flush it out, new filter and fluid and replace the seals.
filter, fluid and seals. good to go.
or, just run it, realize that it does leak, then pull it, and then do the seal swap. tell your lame-o buddy to do it right. for what it would take to do it now, as opposed to later, do it now. think he'd like that better?
At least do the input seal because you can replace the rest without having to pull the trans out.
Speaking from experiance it SUCKS when the input seal (torque converter seal) goes out. It took me 24 QUARTS of tranny fluid to get it home At least no one tailgated me because their windshield would be coated with ATF in a hurry |
Going threw the very same thing myself. I pulled the trans out of a full size truck that I had driven and know the trans was good. It's been sitting now for three years....I figured, IF, there was any problems after it was in........What a PITA it would be to pull the darn thing back out to fix something I could have prevented to begin with......
A Master Rebuild kit that comes with all the seals, gaskets, bushings, thrust washers, frictions, and steels is under a hundred bucks off Ebay. Seems cheap for the piece of mind knowing I won't have to fool with the trans for years to come. Dan |
| need opinions on "the look" | frackster66 | Hotrodding Basics | 33 | 02-12-2006 07:42 PM |
| Opinions on selling my combo.. | draven | Hotrodders' Lounge | 12 | 04-10-2005 12:15 AM |
| Opinions: Is driving at a low RPM bad for your engine? | hlweyl | Engine | 10 | 09-17-2004 08:04 AM |
| daily driver opinions | 87442lover | General Rodding Tech | 4 | 02-13-2004 06:42 AM |
| Opinions on carb, headers, and distributor | 406chevelle | Engine | 9 | 02-11-2004 03:03 PM |
