Opinions about transmission service/flush - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-25-2010, 11:43 AM
"I think the transmission service machine is the biggest ripoff in recent automotive history."
You have not had a shop try to sell you an engine flush along with the engine oil change?
That is why I like changing my own engine oil. After remoiving the drain plug, I let it sit overnight. I get about a half quart more dirty oil out of the engine that way.
This is another good reason for changing engine oil around 3000 miles. The old oil left in the engine is not really that dirty.
  #17 (permalink)
Old 12-27-2010, 08:48 AM
Originally Posted by T-bucket23
I think the transmission service machine is the biggest ripoff in recent automotive history. There is no point to changing the fluid without replacing the filter. If the fluid is bad, most likely the filer is at least partially plugged.
Working at the dealers I made a ton of money off these machines. After opening my own shop I wouldn't touch one. Why? I don't rip off my customers! "Wallet Flushers" is the industry term. Feel free to buy the service if you think it suits your needs - and if you don't mind the snickering behind your back.
  #18 (permalink)
Old 12-27-2010, 08:53 AM
Originally Posted by crussell85
wouldn't a reverse flush be like blowing out an air filter while in the air box of the vehicle?!? I hate when people talk about flushing a transmission, I hate shops even do it. Just change the fluid and filter that you can get out of the pan and call it a day.
There is no such thing as a "reverse flush" when dealing with transmissions. The fluid only goes one direction - the machine doesn't even use a pump as it relies on the transmission pump to do it's work. Any attempt to reverse the fluid would simply blow the fluid out of the lines and into the trans pan. None of the flush machines (coolant, trans, fuel) are setup for reverse flow. Some of the chemicals are good and do a nice job of cleaning up things, but that's it.
  #19 (permalink)
Old 12-27-2010, 04:12 PM
Transmission flush is a rip-off.
My wife has a Honda Pilot. The Honda owner's manual is clear and states that you should NOT flush the trasnsmission fluid. The Honda dealership said if the owner feels like he must flush the transmission fluid, the only way to do it is to replace what fluid comes out when you remove the drain plug and do it four or five times between recomended oil changes. That will eventually replace all fluid in the transmission with fresh fluid.
I use the same method to chage the power steering fluid. I use a siphon pump and draw about a pint of fluid out of the power steering reservoir, without uncovering the fluid lines. I do that two or three more times in 1,000 miles. I don't want to draw too much out of the power steering fluid reservoir in order to prevent air from entering lines as would happen if remove all the fluid at once. I use the same procedure to replace the gear oil in the front and frear differential of my S10 Blazer 4WD . They do not have drain plugs. These are probably the reasons honest auto repair shops don't recommend doing it.
  #20 (permalink)
Old 12-27-2010, 05:33 PM
There isn't a vehicle out there that recommends a trans or any other flush. A few, as above, print in the manual to not do it and GM as well as others have printed technical bulletins warning to not flush. That doesn't stop many shops, especially dealers, from upselling this snakeoil.
  #21 (permalink)
Old 12-30-2010, 11:01 PM
1800guy's Avatar
Here is what has worked for me for many years, on AW 70/71 transmissions. I drive the car long enough to get the trans oil hot, then disconnect the output line from the cooler and use a hose to direct the flow into a gallon jug. Start the engine and add fresh fluid at the same rate as it is pumping out into the jug - change jug when it is full, and keep going until the fluid runs bright red coming out. 8 - 12 quarts usually is plenty. Maybe I'm just lucky, but I've had no problems with not changing the filters, and these are cars I pull my tow dolly with, as well as a two-wheel tilt bed car trailer. I do this at 25 K on the cars I tow with and 50 k on my wife's commuting car. So far so good, your mileage may vary, etc.
  #22 (permalink)
Old 12-31-2010, 02:50 AM
Drewnashty's Avatar
sitis nam accelero
My neighbor has owned and operated a transmission repair shop for about 15 years. He told me that he will not change the fluid in a transmission unless he knows the owner and the history of the transmission. If the transmission goes out after his shop changes the fluid, he will have a difficult time proving he is not liable. He felt like the minor benefits in changing the fluid is not worth the effort and expense. ...
I've worked for a few different locations that require the customer to sign a waiver if they do not have a record of the transmission service being done for liability issues. Sometimes cleaning out what was stopping a leak can cause serious problems.
TH350 transmission oil level at kickdown cable seal Elder Rodder Transmission - Rearend 3 11-13-2010 07:22 PM
Blower transmission shifts soft at low RPM's tubbedz Transmission - Rearend 17 10-01-2009 11:38 AM
How to disengage transmission from block? El Raton Transmission - Rearend 10 11-26-2005 07:55 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
B&M Holeshot converter opinions RObs71Nova Transmission - Rearend 4 08-14-2005 12:04 PM
