Opinions on best option: truck manifolds are too big on 5.3 LS - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 09:16 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
Hello,
I'm installing a 5.3 LS from a '03 Silverado in my 1937 Chevrolet 4 door. As you can see in the picture the exhaust manifolds aren't going to fit. I'm wondering what is the most reasonable option. This is going to be a daily driver for my wife and we're not looking to win any races, just carry our family around. I have read that these years motors had very good manifolds and that shorty headers wouldn't be any better than stock manifolds, but I'm not sure if stock manifolds would clear in this situation. I usually work on old stock motors and I'm not sure about the reliability of new headers. We intend to drive this car for the rest of our lives and are looking for the most reliable option. I'm not sure about all the available stock options.
Thank you,
Brandon
Old 04-02-2012, 07:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are a couple good choices:
Block hugger type headers w/a ceramic in-and-out coating, or made from stainless steel. The ones below are Doug$ headers (ceramic coated), there are others less expensive like by Patriot, but they're uncoated.
A set of cast iron Hooker manifolds, shown below (click on images for more info):
Old 04-02-2012, 10:10 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
those hooker manifolds are cool
the electronic controlled engine guys may have a quicker answer for stock stuff
Old 04-02-2012, 10:11 AM
Vetteman61's Avatar
Thanks. I checked out the Dougs and man you were right about the dollar sign. I think the Hooker's may be the best choice, depending on how much a stock set of vette manifolds might be.
Thanks for the response,
Brandon
Old 04-11-2012, 09:22 AM
is there a Dorman replacement manifold for the vettes from Advance/Schucks etc etc?
Make sure they have an exchange policy and explain to the senior curmudgeon what you're doing. take em home and try. You may even need a vette manifold on one side and a truck on the other.
For longevity and less heat radiating into the cabin, Id definitely use a cast manifold, you could even have em coated to look nicey nice. Id do all your mockery and test firing before you get em coated though
Old 04-11-2012, 02:34 PM
IATECH's Avatar
Gary
Last journal entry: 1950 Mercury Project
headers
We are installing an LS2 truck motor in a 57 Chevy with the same problem. Patriot makes a very nice ceramic coated header that works with a reasonable price. Purchased them through Ecklers. Another option we toyed with was having the flanges milled to bring the stock manifold in closer to the block but it removes way too much material by the time you get enough angle for clearance.
Old 04-27-2012, 07:59 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
you still have that old stovebolt? those are cool engines. Not real powerful, but just neat. I'd keep it on a stand and fire it up once in a while just for kicks.
Old 04-27-2012, 11:41 PM
Vetteman61's Avatar
I kept the 216 from the '37. It's in the barn. I rebuilt the original 235 stovebolt in my daily druver '57 chevy. Also have a 194 in my '31 chevy,
Old 05-27-2012, 12:58 PM
Manifolds
You could look into the 97-99 Corvette stock LS manifolds. I am putting a 5.3 into a 47 Chevy and found the same clearance issue. I have ordered a set of the vette units but have not received them yet, so the jury is still out. Seems to be the main units to use in this case for clearance. If you chose the vette units I recommend going to a Corvette forum and contacting the vette owners. The first upgrade they do is pull the stock exhaust and replace. A much cheaper price from them than auction sites, saved me a good amount.
Old 05-27-2012, 04:25 PM
Vetteman61's Avatar
I recently wound up going with Sanderson headers. I haven't gotten them yet but after talking to several of the guys at the Goodguys show here in Nashville that seemed to be the way to go.
Brandon
Old 05-28-2012, 07:15 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Sanderson's were the only thing I could find (at the time) for my 59 with a 454HO.
I bought the cast iron headers and had them coated later.
Very happy with them, and the coating that was done almost locally
seems to be holding up as well.
Been six years on the car---just fine.
Old 05-28-2012, 11:39 AM
Vetteman61's Avatar
Did you use gaskets or just go with the RTV as they prescribe?
Brandon
Old 07-29-2012, 08:13 AM
I found this thread through google looking for 5.3 deck heights. Why this showed up I have no idea but I have something to add to this even though I'm sure you have figured something out by now, I'll offer these suggestions.
1. All factory truck and 99-02 fbody manifolds are very large and boxy because they are cast iron
2. Factory 98 fbody manifolds are actually stainless steel. So you could cut the flanges off and weld an extenstion to it.
3. Vette manifolds are well,,, Vette manifolds and their application and fit can almost always be questioned.
In case you guys didn't know, the Ford 302 exhaust port spacing is exactly the same as the spacing on a GM LS motor. ford headers to lsx - LS1TECH Thus, what alot of guys in the LS world do with swaps is they purchase a set of 302 headers that will work and cut the Ford flange off. Then purchase a set of GM Performance LS flanges and weld them up GM Performance 12480130 - GM Performance Header Flanges - Overview - SummitRacing.com . You have a much larger pool of vehicle types and header configurations to compare by throwing a 302 Ford into the mix. Obviously the ford ports are rectangular so you will need to oval them out with a pipe expander or something like this with some heat
Amazon Amazon
Also don't overlook the possibility of modifying a shorty header off an Fbody to fit like I did.
The Following 3 Users Say Thank You to kossuth For This Useful Post:
77amc (08-19-2012), cobalt327 (07-30-2012), Gabbyp (10-06-2012)
700R4 manual shift option only opinions russ69coupe Transmission - Rearend 2 10-13-2011 04:57 PM
opinions on painting my truck chevy1500z71 Body - Exterior 7 07-18-2011 02:47 PM
Exhaust manifolds or headers for 1952 Chevy Truck NickO General Rodding Tech 7 02-04-2011 05:43 PM
Engine option opinions wanted.... woodscavenger Engine 22 01-24-2011 03:29 PM
Looking to buy a truck, want opinions zipfactor Hotrodders' Lounge 4 04-16-2009 09:34 AM
