Opinions on electric fans and shrouds - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2004, 11:51 AM
Wiki Edits: 49
I had planned to run a Spal 16" electric "S" blade puller fan (2200 CFM) with a shroud but I don't have enough room between the water pump pulley and the radiator to fit both the fan and the shroud.
I can do one of the following:
1. Omit the shroud and just use the Spal 16" electric fan (puller).
2. Modify the shroud and run an 18" mechanical fan.
3. Omit the shroud and run dual 11" electric puller fans (2800 total CFM).
This isn't a real high performance installation. 343 cu. in., 8.5:1 compression, single 600 Edelbrock, muscle car cam, dual exhaust and air conditioning.
I'm looking for trouble free operation and I don't want to worry about overheating on summer days in heavy traffic.
I know which way I'm leaning but would like some second opinions.
Thanks
Centerline
Old 05-28-2004, 02:21 PM
CL, I'm running a 2700 CFM 16" fan on my 383 powered PU. A shroud is not needed because the fan itself has a mini shroud and it is installed so close to the rad. No overheating problems because I have a big Griffin rad with lots of coolant capacity, a 17 psi cap, and a thermostat for the heavy duty operation. I run the electric because I do not have the room for a shroud or a belt driven fan. It is my understanding that one big fan is better than two smaller fans and a puller (one installed behind the radiator is more efficient than a pusher.
The not so good news is the big fan draws a bunch of amps and proper wiring for that reason has been covered very well in the Electrical Forum.
Trees
Old 05-28-2004, 02:33 PM
Wiki Edits: 49
I'm running a PRC aluminum radiator so coolant capacity shouldn't be a problem. The only problem with running the Spal 16" puller is I have to run it high on the radiator core to clear the water pump. With the dual fans I can run one high and one low.
I had the feeling that a shroud wasn't really needed with electrics for the same reason you mentioned.
Thanks for your input.
Centerline
Old 05-28-2004, 02:37 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I vote for the mechanical fan w/ shroud.
