Opinions on this engine combonation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2003, 09:56 PM
glock35ipsc's Avatar
This is what I plan on putting together for my 56 Buick Special. It has been modified with the soon-to-be small block, a TH350, and the entire 10 bolt rear end and suspension out of a 71 Chevelle.
I bought a standard universal Goodwrench replacement 350 (non-Vortec 76cc heads, 8.5:1 CR), said to be around 250HP. I have a few extra parts in the shop I plan on using on it:
Comp Cams 268H
Professional Products manifold (similar to an Edelbrock Performer)
Road Demon 625 CFM carb w/electric choke
HEI with MSD module and coil
Pete Jackson gear drive for the noise (it's the quiet one )
And a ton of chrome and billet aluminum parts (tin, brackets, etc.)
I am not looking for a tire smoker, just something that has a good sound at idle, is dependable, and is effecient.....something I wouldn't be afraid to hop in and drive to South Dakota (I'm in Colorado). I was going to put my BIG big block in here, but I decided to make this my cruiser and make the Camaro the racer.
It has a stock converter, so I thought about something in the 2000-2200 RPM range. The rear has 3.73's in it, and a 265/60-15 tire on an 8" rim.
Does this sound like a reasonable combo, especially given the 76cc heads and 8.5 CR? I really dont want to pull the motor apart to replace heads or pistons to bump up the compression, but rather use what I have in the shop for an inexpensive, but reliable cruiser.
Thanks in advance!
Old 07-11-2003, 05:12 AM
BigRay's Avatar
Thumbs up
Sounds like a good set up ,Go for it .
BigRay
Old 07-11-2003, 07:21 PM
BOBCRMAN@aol.com's Avatar
A good common sense reliable motor (except for the gear drive!)
