Opinions on this motor combo
I have a 350 SBC bored .020,flat hypereutectic pistons,stock (5.7) powdered rods,stock crank(3.484 stroke).I planned on buying AFR 190cc vortecs,lunati 60112 hydraulic roller(231/239 dur.@.050 535/550 lift and 110 lsa),comp roller rockers(1.5),rpm air gap,and holley 670 cfm.This is going in a 61 Chevy truck with 3.90 rear,TKO-600 tranny and 27" tall tires and power brakes.Truck will be used for fun/streetrod.Is this a good combo?Should I go with smaller heads/cam?Any advice is appreciated,Thanks!
You can read in hundreds of threads on this board, "on the street, torque is king!". As such I think you would benefit from slightly smaller intake runners.
With that cam you could put 190cc of runner to use in higher rpms, but it would come at the cost of low end torque, and is that what you really want? Then again you may need more than 670cc of carburetor to hit those higher r's, and a cast crank??... I say go for the bottom end torque.. Just my .02c.. YMMV. |
good idea setting a plan before spending money ,,,,, I wish I had enough sense to do that on all my builds
F-bird88 helped me pick my cam. I think if your cam choice was not a good one he would have told you.. G-luck with your build..
The only "issue" I have with your set-up it the rearend gear ratio 3:90 is abit steep in MHO (semi-surprised no one else has said any thing!??) I'd go no steeper then 3:73 with an idea set-up at about 3:50. Driving down the freeway with 3:90 is NOT fun!!! ...Been there! ...Good Luck!
afr is the best head on the market in my opinion,if u want a really good head and cam combo.ed curtis can custom grind u a cam for about 50 more than a over counter cam price.he made me a believer when my buddy has a 90 stang 302 stock internals except cam,afr heads,air gap intake.he runs 6.98 all day long and a high 10 in the 1/4 mile.he out runs strokers 331s,347s.running 410 gears threw a c4 3 speed automatic. ran a 6.37 on a 100 shot with a smaller set of afr's was 165 now he runs 185's when he changed heads ed reground him a cam,
| I need opinions on 2 cams | batman09 | Engine | 4 | 11-04-2008 09:06 AM |
| Opinions On AMSOIL | RCastle | Engine | 8 | 12-13-2007 12:21 AM |
| Opinions on selling my combo.. | draven | Hotrodders' Lounge | 12 | 04-10-2005 12:15 AM |
| Opinions: Is driving at a low RPM bad for your engine? | hlweyl | Engine | 10 | 09-17-2004 08:04 AM |
| Opinions on carb, headers, and distributor | 406chevelle | Engine | 9 | 02-11-2004 03:03 PM |
