Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Opinions needed on BBC swap vs upgrades for 350
Old 03-26-2013, 05:38 PM
vht vht is offline
I wouldn't throw a set of heads on the 350 without going through it 1st. If I was going to use the 350, I would consider a 383. That would give you a little more torq for towing and you could still get decent mileage. The BB will out pull and out run the SB but the 1 I done for the same reason as you are sure liked the gas. Towing or not.
