Opinions Please...
Heres my plan: I have a 400 sbc 511 4 bolt block with the stock crank and rods. I'm going 30 over and plan to use Lunati's Voodoo series solid flat tappet #60143,
Int Exh Adv duration 296 306 Duration @ .050 257 265 Lift .560" .580" LSA 110 ICL 106 with 10.5:1 cr. My ? is do I go with the AFR 195's or 210's? Also going with either, would it be better to go with a dual plane like the RPM air-gap, or a single like the victor jr. Topped off by a holley 850 dp. It's going into a 73 Nova with a 4 speed and 4.10 10 bolt. It's a street car with an occasional strip pass. I think with the right set-up, I should be in the 11's. I just have to get it to hook up. Thanks in advance for all words of wisdom, Joe |
I think you would be in the 11's too. However in my expeience stock rods and cranks in a 400 sbc don't hold up to a lot of rpm for real long. I try to keep my stock bottom end stuff under 6,000 rpm. That would lead me to a smaller cam and a good dual plane intake.
Smitty-
AP is correct here... 'go a cam or two up' the page and look for a single pattern cam- which I don't think the Voodoo line has but other Lunati grind familys do. The AFR's have impressive I/E % so you would be better served power wise with a single pattern cam. |
I think Double Vision hit the nail on the (AFR) head. A cam in the mid 230s, and maybe use 1.6 rockers. Remember the AFRs have an I/E ratio that almost wants a cam with greater INTAKE than exhaust duration. Try it on some of the Computer dyno simulators. Consider a single pattern hydraulic roller. I think that'll get you wherever you're going PDQ.
Pat |
Thnx for the tips. I already have the air gap and carb. Any specific cam suggestions? I originally thought of going with the edelbrock rpm heads and cam package but I thought I was leaving alot left to be desired. I thought the 170 runners of the rpm's would be a bit inadequate. 195 or 210's and a bigger cam might be better to get me where I'm looking to be.
air gaps are a pain to drive in cold climates. slow warm up on the carb leads to bad stumbles off idle. even 50F days causes issues. takes 30 minutes of driving to get good throttle response. I would use the regular RPM intake and get a set of heads with exhaust cross over for a street car.
you can get around 500hp/500 ftlbs with a set of afr's and a cam in the 230 degree range with a 406. do a web search "impersonator II and chevy high performance" here you go. http://www.chevyhiperformance.com/te...ild/index.html |
I had no idea about the temp problems with the air gap.
| I need opinions on 2 cams | batman09 | Engine | 4 | 11-04-2008 09:06 AM |
| Opinions On AMSOIL | RCastle | Engine | 8 | 12-13-2007 12:21 AM |
| Opinions on selling my combo.. | draven | Hotrodders' Lounge | 12 | 04-10-2005 12:15 AM |
| Opinions: Is driving at a low RPM bad for your engine? | hlweyl | Engine | 10 | 09-17-2004 08:04 AM |
| Opinions on carb, headers, and distributor | 406chevelle | Engine | 9 | 02-11-2004 03:03 PM |
