Opinions on proper Plugs for SBC with aluminum heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2008, 06:37 AM
383 Stroker
-5cc flat top pistons
w/ 64CC heads (pro comp aluminum) estimated compression from Eagle (bottom end) is 10.7:1
I think (??) the recommended plugs for the aluminum heads are Champion RC12YC (Autolite 3924); however the current plugs are a hotter plug Champion RC14YC (Autolite 3926). These plugs are a gasketed, .750" reach plug. Should I be running the cooler "recommended" plug for this setup ? Thanks.
Old 09-26-2008, 07:09 AM
racecar100's Avatar
The plugs are little too hot for your compression. I'd go with RC8YC or RC10YC.
The Autolite 3923 to 3924 is better heat range over the Champion.
Cast or Aluminum Heads for Alcohol S10 Racer Engine 1 12-25-2007 04:50 PM
patriot aluminum heads brickhead Engine 1 11-19-2006 10:08 AM
Looking for a decent aluminum head around ~$1000 - new summit heads? Warrant Engine 14 11-05-2006 10:25 PM
Aluminum Heads?? HotRodMan Engine 3 11-18-2002 01:34 PM
Aluminum Heads bishop Engine 1 05-09-2002 08:30 AM
