Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - opinions on Uni tech speed blaster w/ recovery bag
Old 01-03-2013, 08:01 PM
tech69 tech69 is online now
put up or shut up
I get sand blasting sand that has a uniform size, don't know the grit. But I get it at the local Ace Hardware in 40lb bags.
thanks, Martin. I'll go to Ace and check it out.
I notice the trigger gets stuck but am assuming it's due to sand flowing backwards into the area of the trigger. I have a hunch that by turning it off first and keeping it triggered for a second it will clean it out and keep that from happening, also assuming you should empty the collector bag asap as to not do the same and allow the sand to flow backwards.
