opinions on vortec heads and intakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2002, 03:44 PM
stfinney's Avatar
Post opinions on vortec heads and intakes
Are the vortecs worth getting? What are your opinions on the vortec bolt-ons??
Old 11-20-2002, 03:54 PM
Post
The vortec heads flow better than any stock chevy head ever made. The downside is that the casting is not very strong and you will have to get them worked for a good lift. You can buy aftermarket heads for the same price that flow better.
Old 11-20-2002, 04:05 PM
Post
alot of resorces say its almost impossible to port the intack without a flow bench and make it better. theirs also not alot of meat around the ports. but that just shows how good they were from the factory. not to argue with burn but i have never seen any headsthat are cheaper than the vortecs and flow better.
Old 11-20-2002, 04:16 PM
Post
Check the new Scoggin dickey catalogue it will list the flow specs of all the heads they sell. One of them is alot better than the vortec at the same price. Around 212$ a head.
Old 11-20-2002, 04:19 PM
Post
It's hard to believe but I've seen quite a few of them crack working at the junk yard.
Old 11-20-2002, 04:21 PM
Post
cheap and if their not 18 degree heads than you can use a normal intack which saves money in the long run. although the prices for vortech manifolds seem to be falling a little bit.go getem burn
Old 11-20-2002, 04:26 PM
Post
Do you know alot about tpi?
