Opinions wanted - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2006, 05:36 AM
SVOHIO's Avatar
Whats racecar spelled backward
Opinions wanted
I plan on spraying my car in the spring after I finish prepping it. I'm going to rent a spray booth by the hour. The car is currently white and the new paint will be a brighter white. My question is do I need to bother with a two stage paint, don't most companys make a quality single stage paint? And as far as I know a single stage can be color sanded and buffed,right?
Old 12-23-2006, 07:05 AM
adtkart@aol.com
Do you need to bother with a 2 stage paint? That's up to you! It depends on what you want as a finished product. BC/CC will last longer. It is also easier to spray if you are new to painting, as mistakes can be repaired as you go along. If you get a run in the base, you fix it before clear. After the base is the way you want it, you shoot the clear. If there is a problem with the clear, you can fix that, and shoot more clear on it.
My understanding is that you can sand and buff single stage if it is not a metalic color. Since I use very little single stage, I can't say that for sure, but that is my belief.
Aaron
Old 12-23-2006, 08:59 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Aaron,
You need to try some of the SPI white single stage.it is pure white and it buffs out just beatiful..I have found with single stage if one gets a flaw it is a simple matter to sand out the flaw and shoot a touchup..good stuff as far as I am concerned..BC/CC I think is best when a guy is doing candies and or pearls and flake..or wants that real custom color..
Sam
Old 12-23-2006, 09:53 AM
adtkart@aol.com
Sam.... I have used the SPI Black SS, but never had to sand and buff anything that I applied it on. Not that I am that good, just that I used it on a roll cage, engine compartment, and suspension parts. I have not tried the whites yet. I try to not paint anything white.
Aaron
Old 12-23-2006, 10:10 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
Sanding and buffing work better on clear coat, IMHO. I only use SS when any buffing will be very light.
Old 12-23-2006, 10:19 AM
Yes they can be buffed, but what color are you planning on? As mentioned, if it is a metallic, you just can't buff it to any degree.
I feel that the basecoat clearcoat is SOOOOOO much easier. It is kinda like baseball compared to basket ball. You can take your time and lay it on.
Opinions Wanted, All Car, Car Show xxllmm4 Hotrodders' Lounge 28 02-04-2011 06:17 PM
Devilbiss FinishLine Spray gun opinions wanted rodnok1 Body - Exterior 5 11-17-2006 06:07 AM
Opinions wanted ... Thanks !! Gr8lite Hotrodding Basics 5 07-14-2005 08:36 AM
The new "Cammer", in an Edsel? All Opinions Wanted bigedd396 Engine 1 02-22-2004 12:56 PM
opinions wanted Lightspeed Body - Exterior 12 10-07-2002 06:38 AM
